gyle kugler
90 points
Posted on - 06/21/2012
Hi, when I was trying to install Nero 8 in my windows system, Windows 7,it noticed me with a corruption of a file. But when I ignored that it was showing ERROR 2350. I retried the process but the result was the same. Please get me out of this problem. Want your help. Thanks.
Nero 8 installation problem (Error 2350) ?
Dear Gyle Kugler
This is a common problem for Nero 8 Install. Most of the time users are facing problem of Error 2350.
But Need not to worry about this, the solution is very easy.
I am also suffered from this problem. I give you the solution of this problem. Just follow the tips.
Step 1: First of all remove or disable your security protection. (Antivirus Program), because A CAB file that is scanned while nero is trying to install, the file will be recognized as corrupt. So If you need to install Nero 8, Just disable your antivirus.
After Disable your antivirus you can install Nero 8 As usual.
After finishing your installation you can again activate your antivirus program.
Hope you will get benefit from this.
