Hello All,
I recently installed the Nero 9.2.6.0 lite version. But till now I had no success trying to get it to work. I am getting this error message that I have attached in the below screen capture. It says something about a side-by-side configuration being incorrect and I don’t know how to resolve this problem. I was using Nero 7 earlier and had performed an uninstall using a clean utility before downloading this installer. I have applied all the recent windows updates on my windows 7 machine and I tried updating all the other software on this machine when I received this error. I tried to start Nero again after restarting my computer with all the updates in place. Still this problem persists. Then I tried fully uninstalling Nero and then restarted my machine. Now I use the Nero Clean Tool to remove whatever remnants may be left. Again I restart the machine. Then I completed a fresh install of Nero smoothly. I tried running the application again and I find that I am back to square one. This is truly exasperating. What next? Please, somebody help me. Many thanks in advance.
C:program FilesNeroNero 9NeroExpress.exe
The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail.
points
Nero 9 application fails to start with an error message
This is the error because of Microsoft Visual C++ Redistributables. Here, all versions of MS Visual C++ Redistributables are given below. Download and install all the versions and then, run the program.
Be careful before installing these programs. If any older version is installed before, uninstall all.
Download all those redistributables from this page. Then your problem will surely disappear.
MS Visual C++ Redistributable is required to run programs perfectly that are being developed using MS Visual C++. This package installs necessary runtime components for running the application.
According to Microsoft, you may receive “side-by-side configuration” error if your computer is missing the correct Microsoft Visual C++ runtime components for the type of system you are using (32-bit or 64-bit). To fix the problem, download and install the following Microsoft Visual C++ update according to your platform architecture:
- Microsoft Visual C++ 2008 Service Pack 1 Redistributable Package for x86 – for 32-bit Microsoft Windows. It supports Windows 2000 Service Pack 4, Windows XP, Windows Vista, Windows 7, Windows Server 2003, Windows Server 2008, and Windows Server 2008 R2.
- Microsoft Visual C++ 2008 Service Pack 1 Redistributable Package for x64 – for 64-bit Microsoft Windows. It supports Windows XP, Windows Vista, Windows 7, Windows Server 2003, Windows Server 2008, and Windows Server 2008 R2.
- Microsoft Visual C++ 2010 Redistributable Package for x86 – for 32-bit Microsoft Windows. It supports Windows XP Service Pack 3, Windows Vista Service Pack 2, Windows 7, Windows Server 2003 Service Pack 2, Windows Server 2003 R2, Windows Server 2008 Service Pack 2, and Windows Server 2008 R2.
- Microsoft Visual C++ 2010 Redistributable Package for x64 – for 64-bit Microsoft Windows.
If your operating system lacks the required Service Pack update, download the required Service Pack update from the following:
For Windows 8, you should update to Windows 8.1 from the Windows Store.
