Nero 9 create a dvd slideshow gui
Greetings everyone!
I would like to know if is it possible for Nero 9 create a dvd slideshow gui? Please provide me step-by-step procedures with pictures on how to create a dvd slideshow gui using Nero 9.
Greetings everyone!
• Launch Nero Vision to create your custom slide show.
• View the "Start" screen to select the "Make Slide Show."
• Chose options to create a slide show on DVD-Video, Super Video CD, miniDVD, AVCHD or HD-BURN.
• Add images to your slide show by clicking on the "Browse" button.
• View the "Open" window and upload and add files to the media section.
• Check out media area to select the valuable images that you would like to include in your slide show and click the button to "Add" files.
• View images that are now inserted in the contents area of your slide show tools and tab.
• Repeat above steps to add more images to your slideshow.
• Click the "Play" button to view your rough draft.
• Review edits spellings, image possibilities and content relevance. Select the "Next" button once you are satisfied with any edits noted or changes made.
• Preview entire slide show in the content screen to see each page.
• Save the initial draft of the slide show to a desired location.
• Back up your slide show and slide show images to disc. Save the file in a format that is readable to your PC.
