sabinjamal
10 points
Posted on - 06/28/2012
Hai all,
Somebody please tell me which version of the nero can perform a mp3 cd burning.
I want to burn some mp3 songs, which i can play it an mp3 player….
I have tried data disc burning but the files aren't playing in the mp3 player…
And also please provide a link for downloading the nero which have these functions.
Nero for burning files as mp3 cd
Hi Sabinjamal,
Making MP3 CD or even DVD in nero is an easy job. This can be done starting from version 7 and all the newer versions up to version 11.
Follow these steps to get your MP3 CD:
1- Choose audio from the main screen of Nero Start Smart.
2- Now choose Make MP3 CD.
3- Click the Add button in the My MP3 disc window that will appear and then browse for the MP3's you want to add then press Close when you are done adding files then next.
4- Now you have to select the final settings for your CD and the CD name then press BURN when you are done. A Progress bar should start and when its complete a success message box should appear and thats it. Your MP3 CD is ready.
-If you want your tracks in certain order then you may want to name them like this:
001_Track1.mp3
002_Track2.mp3
003_Track3.mp3
Finally the link to download and purchase nero 7 is http://www.nero.com/enu/downloads/previous-versions/download-nero7-free-update.php
Hope this helps.
I have a nero of version of 11. When i click on the audio cd from the home screen, a window pop ups and says to upgrade…
MP3 is MP3, there is no special technique when burning it on a CD or DVD disc. When you burn MP3 files on a CD or DVD disc, it should play on any CD or DVD players. If your MP3 player can’t play the MP3 music you burned on a disc, you should try burning your MP3 files in audio disc format or by creating an audio CD.
The resulting disc will be similar to the ones you buy on music stores from popular music artists. Also, try using ImgBurn to burn your MP3 files. ImgBurn allows you to create audio CDs from any format supported by DirectShow/ACM like AAC, APE, FLAC, M4A, MP3, MP4, MPC, OGG, PCM, WAV, WMA, and WV. “MP3” (.mp3) is the shortened format for “MPEG-1 Audio Layer-3.”
It is a standard technology and format for compressing a sound sequence into a very small file, approximately one-twelfth the size of the original file, while preserving the original level of sound quality when it is played.
