Nero Burning ROM Data verification failed
Today I have burned a DVD and I have selected the option to verify the DVD after burning. After the burn process finished it appeared that are some problem in verifying the data on the DVD. I don’t know what to do next. Should I burn other DVDs ? Is any problem with my DVD optical drive and why I have this problem ? Please help !
Thanks !
Nero Burning ROM
Answered By points N/A #187780
Nero is one of the best data burning software for everyone. This burns data smoothly on every CD/DVD but there are some limitations always.
This error means that some sector of the disc is unreadable so the burned disc contains corrupted data. Although the burning process is perfect, it is faulty.
It mainly happens when you’ve got bad quality of disc. If any defective CD/DVD is in use, this error will appear.
Just you’ve to do is to use any other DVD. Otherwise the DVD will provide corrupted data and will do problem in the future usage.
Answered By 590495 points N/A #326619
To see if the problem is with the burner, try to uninstall and reinstall Nero then burn another disc. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select Nero among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install Nero back. Once installed, try burning another disc. If the problem is the same, try burning using ImgBurn instead. It is a CD and DVD burner that you can download and use free of cost.
