Hello there,
Even I have updated LightScribe this error still appears. The disc type is the same that I used before which worked just fine. Is there anyone who can help me with this error please ? Why it doesn’t work now ?
Thanks !
Nero – LightScribe
The drive resource file does not support this disc type.
An update of the LightScribe host software may fix the problem.
Click Ignore to show non-optimized preview.
To download the latest LightScribe host software click here.
Nero light scribe shows incompatibility issues
To make sure the LightScribe System Software is up-to-date, download and install LightScribe System Software 1.18.27.10. I guess this is the latest version since it was only released last year. It requires Windows 2000, Windows XP, Windows Vista, Windows 7, and Windows 8. Try it again once LightScribe is updated and see if it works. If it still doesn’t work, check the disc you are using.
It is possible that the disc you are using doesn’t support LightScribe. Remember that you cannot use LightScribe on an ordinary CD because it requires a special type of CD that supports LightScribe technology. LightScribe is an optical disc recording technology that uses specially coated recordable CD and DVD to create laser-engraved labels with graphics or texts.
The LightScribe optical disc recording technology was designed by the Hewlett-Packard Company by engineer Daryl Anderson, the man who invented it.
