Nero Vision Express does not work
Hello, I installed Nero Vision Express successfully and it worked well. After using some days, I got this error message: “Untitled Project *[DVD] – Nero Vision Express: NeroVision.exe – Application Error”
I searched on the web but could not get any right solution. I would request a solution from anybody, please.
Answered By 0 points N/A #103363
Have you confirmed whether the Nero Vision express installed is  compatible with you windows? If this is the underlying problem it will be appropriate for you to find the most compatible Application from the website Nero.com.
It could be that you are missing some drivers so it would  also make sure that you are up to date.
The problem with Nero Vision Express is that it is known to have the lowest Mpeg Encoders so if the problem is not solved then it would be better if you looked for an Encoder that converts your files to correct Mpeg  format.
