Nero Vision start up error
When I start Nero Vision software on Windows 7 am getting an error message as shown below.
How can I solve this?
The program requires the file advrcntr.dll, which was not found on this system.
There are three reasons for the following error to occur:-
1 > The following file is missing in the installation directory in that case I would suggest you to download the whole installation file once again.
2 > Your operating system is corrupted although this is very case but it can occur.
3 > The following .dll could not be located So I suggest you to install the .dll after downloading it from  https://www.dll-files.com/advrcntr.dll.html Into your C:/ drive where your software is installed.
