rizwan
280 points
Posted on - 06/28/2011
While studying for MSC, I am facing problem with Nested Join, Hash Join and Merge Join in SQL query plan.
Can anyone help me with this?
B.lie
25 points
I also faced similar problems while I was studying and consulting different books got the answer. The system scans the entire inner-join relation for each tuple in the outer join relation in nested joins and appends any tuples that match the join-condition to the result set.
If both join relations are sorted by the join attribute(s) and come in order, the system performs the join trivially in Merge joins. Current group of tuples from the inner relation with a set of contiguous tuples in the inner relation with the same value is considered in the join attribute.
For each matching tuple in the current inner group, add a tuple to the join result. Once the inner group has been exhausted, advance both the inner and outer scans to the next group. Hash join A hash join algorithm can only produce equi-joins.
The database system pre-forms access to the tables concerned by building hash tables on the join-attributes.
abrarad
Merge join, Nested join Hash join in SQL Merge join is also known as sort merge join. Merge join sorts by means of join key. It sorts relevant rows in the first table and also in second table. Then merges these sorted rows.
Lets view with through an example. You bought 400 books at a cheap rate. You know some of the books you already have in home. So what you would do? You will sort your home books by means of primary key (Title, Author). Then you sort the 400 books by primary key (Title, Author).
Now you start from the beginning of both pile – if the primary key of the first book of 1st pile is higher than that of the 2nd pile, you take out the book from 2nd file and so on. This is Join merge.
What would happen if the both values are equal? Then you have found a duplicate book!. The behavior of merge joins is influenced by the initialization parameters sort_area_size and db_file_mutliblock_read_count.
Nested loops repeats through all rows of outer table. Whenever any SQL statement applicable only to the outer table has matched condition, then the corresponding rows of the joined inner table are searched. To find these rows from the inner table either an index is used or a thorough search is performed.
Hash join takes smaller table to perform a hash algorithm through the rows and from the columns where the condition is matched stores the result. After finishing one table performs same work on other tables. Then searches the hashed values to find a match. If any found, the row is returned.
mabz143
A join is whenever the two inputs are compared to determine and output. There are three basic types of strategies for this and they are: nested loops join, merge join and hash join. When a join happens the optimizer determines which of these three algorithms is best to use for the given problem, however any of the three could be used for any join. All of the costs related to the join are analyzed the most cost efficient algorithm is picked for use. These are in-memory loops used by SQL Server.
Nested Join
If you have less data this is the best logic. It has two loops one is the outer and the other is the inner loop. For every outer loop, its loops through all records in the inner loop. You can see the two loop inputs given to the logic. The top index scan is the outer loop and bottom index seek is the inner loop for every outer record. It’s like executing the below logic:-
For each outer records
For each inner records
Next
Next
So you visualize that if there fewer inner records this is a good solution.
Hash Join
Hash join has two input “Probe” and “Build” input. First the “Build” input is processed and then the “Probe” input. Which ever input is smaller is the “Build” input. SQL Server first builds a hash table using the build table input. After that he loops through the probe input and finds the matches using the hash table created previously using the build table and does the processing and gives the output.
Merge Join
In merge joins both the inputs are sorted on the merge columns. Merge columns are determined depending on the inner join defined in SQL. Since each input join is sorted merge join takes input and compares for equality. If there is equality then matching row is produced. This is processed till the end of rows.
