Net Framework installation unhandled exception error
I don’t know I have this error because I have the latest version of Microsoft .NET installed on my laptop and also my Windows is up to date. Should I try to reinstall Microsoft .NET Framework again ? Is there a problem caused by the updates of Windows ?
Thank you !
Microsoft .Net Framework
Unhandled exception has occurred in your computer application.
If you click Continue the application will ignore this error and attempt to continue.
If you click Quit, the application will close immediately.
Answered By points N/A #177110
Such issue will appear if your program has something problematic in your program.
Programs developed using .NET Framework requires the runtime to run perfectly on any Windows machine. Specific applications need specific .NET Framework versions so installing the latest one is the easiest way.
The runtime also comes with a good debugger that enables to identify any problematic code running and causing malfunction. The program you’re trying to run has went malfunctioning and so showing this error. This is a debug log that was generated depending on the program’s code.
If you’re the developer of the application, check your code for any malfunction in the functions stated in the box. If you’re not, you can give the developer the message of this error.
For more surety, you can download and install .NET Framework 4.5.2.
Also, see the manufacturer’s website for the latest update of the problematic software.
