NetBeans IDE 7.2 features ?
Can anyone list the features and support what they have added from existing NetBeans to the latest NetBeans.
Is it good to use NetBeans IDE for java based development or should I go with Eclipse IDE.
Hi mam,
hi the new Netbeans IDE 7.2 do have a lot of new features
i will show a list of few updated features
Performance Features
Improves performance of Remote File Systems
Improve project scanning speed
Java Features
they added new factoring and hints
PHP Features
PHP 5.4 support
FTP remote synchronization
C++ Features
its Support new C++11 standard
reduce memory consumptions and it improved parsing performance
and they added a 64 bit launcher for windows.
to find a lot more for Netbeans IDE 7.2 features just visit you can find a lot of information there since it is the official site of Netbeans
Hope your problem is fixed Thank You.
Larry
Hello Margaret,
The NetBeans IDE is a free, as well as open-source Integrated Development Environment that is very suitable for software developers. It has got all the tools that are required for the creation of a professional desktop, enterprise, web as well as mobile applications using the Java platform. It also comes with C/C++, PHP, JavaScript as well as Groovy.
The notable features in the NetBeans IDE 7.2are the following:
Carl
