Netbeans Version 7 fatal IDE Error
Hello guys,
I am using netbeans to refer to integrated development environment (IDE) for developing with java. I have installed the version 7 of IDE but before that I was using the 6.9 version which was running perfectly fine. The version 7 of IDE results in more frequent errors than version 6.9. I don’t know why but I keep on getting the following error message on my screen:
Fatal Error: Cannot recover after last error. Any further errors will be ignored.
From line 12, column 18; to line 21, column 12
Further processing of the file may be significantly affected by this fatal error. Please fix the problem before continuing editing of this file!
(Alt-Enter shows hints)
The code is running exceptionally but these errors keep on coming over and over again.
Can anybody guide me how to get rid of these error messages?
Your suggestions and views are most welcome.
Looking forward to your views.
Regards.
Richie
