NetBIOS Install Check Failed Version 0 Keeps Re-appearing
I want to know what does this error means “NetBios install check failed version 0”? It keeps on repeating. Please help me. Thanks!
This message was implemented in NetBios 1.20a. Wonderware® NetDDE™ ,, but there's nothing to worry about because it's only a status message and it means that WFW 3.11 NetBIOS wasn't detected by NetDDE and that "workaround code" will not be used NETDDE
Hello GIlbert,
What you are getting is a status message and not an error message. It simply means that the NetDDE failed to detect WFW 3.11 NetBIOS that is running on your computer, and therefore it cannot be able to use workaround code in NetDDE.
This message you are getting was implemented in NetBIOS version 1.20a. Wonderware® NetDDE™ version 1.30 does not give you that kind of status message by default, but in case you have enabled "Log All Problems" in the NetBIOS debug menu, then you will get the message "NetBIOS install check for 2.0 version failed. Version Installed: 0".
Hope this helps.
Carl
