Netflix Error Code W8106 103
I am facing an error while using my Netflix account that says Netflix error code w8106 103. I am using it on my windows 8 computer. How can I resolve this? Please help.
When error code W8106-103 appears on your Windows 8 computer or tablet, it usually refers to information stored on the device that requires an update. Follow the troubleshooting steps below for your device to resolve the problem.
Delete the Netflix application from your Windows computer
Open the start menu of your windows, select and press the right click on your mouse over the netfilx application.from the options shown choose for uninstall.
The Netflix app is now removed from Windows.
Install the Netflix app
From the Start menu, choose Save.
Open the search box and search Netflix and then install it.
If signin or signup is needed then, sign in with your Microsoft information.
Return to the Start menu.
Choose the Netflix app.
Select Login.
If you are not yet a member, register.
Enter your Netflix email address and password.
Select Login.
This will solve your problem.
Notifications
