Netflix Player Video Errors and Problems
The video and audio on Netflix are not in sync whenever I’m watching. What can be the problem? The connection is pretty fast so cross that.
Dear,
Your software not properly connected with your computer hardware. Your audio driver is not responding with the video. You can update your audio driver. A new install process can also remove the bugs of audio driver. So try to have reliable software for your audio driver and install that. In case of new install process first remove the old install files.
Thank You.
If you have the audio and video sync problems then you have to follow some easy steps to resolve this problem.
                    Netflix App Audio or Video Issues
I hope you will fix this issue.
