Netflix Service Not Available; Netflix Error Code 108 On Apple TV
Netflix app has stopped responding on my Apple TV, and gives the Error Code 108. I tried restarting the TV but the app gave same error. Any possible solution?
Most of the times this is a network connection error, or you account information in not correctly entered in the app. To check the internet connection and rectify it on your Apple TV follow these steps:
“Error 108” in Netflix often points to a network connectivity problem which prevents the Netflix app from reaching or connecting to the Netflix service. This error code is often accompanied by either of the following messages:
If this error was triggered on an Apple TV 2 or Apple TV 3, try checking your internet connection. On the Apple TV menu, go to “Settings,” “General,” “Network,” “Test Network,” “OK,” and then select “Yes.” After this, select the download speed you expect from your internet connection. If the test was successful, try connecting to Netflix again and see if it works.
If it doesn’t, powercycle your TV. Turn off your TV and unplug it from the power and everything that is connected to it like the network cable for about two minutes or longer. After this, plug the TV back to the power and connect everything you disconnected back to your TV and then turn both devices back on. Try Netflix again and see if it works.
If this doesn’t work, try updating your Apple TV’s firmware. On your Apple TV menu, go to “Settings,” “General,” “Software Updates,” “Update Software/Update automatically,” and then “Download and Install.” Once the update is complete, try Netflix again and see if it works.
Notifications
