Netstat Remoto Execution in Windows 7 64 Bit?
I’m currently in the middle of developing a software for Windows 7 64 bits, which will be able to know the ports being used by running software. It is possible with netstat remote, but I was wondering if there is a way to execute commands for another client, remotely?
Answered By 0 points N/A #132462
There are many software that allow you to execute commands for other clients remotely. There are software that need to be installed on the client server also. If you do not want to install the software on the client system then there are software through which you can execute commands for other clients remotely without installing them on the client computer.
Software that have to be installed on the client computer also are:
1. PC Anywhere
PC Anywhere
2. TelNet.
Software that do not need to be installed on the client computer are:
1. Psexec – You can download it here — http://download.sysinternals.com/files/PSTools.zip
2. WinSCP
