Network and Internet Settings in Windows 8
I change my OS from Win 7 to Windows 8 and I want to set a new network. Â So where can I see the Network and Internet Settings in Windows 8? Thanks ahead for answering.
Go right with your cursor on desktop and click the Search. Then go to Apps and press Esc (key command) to hide the Charm Bar. The next thing is to click on Control Panel who is under the Windows System. Here you can find Network and Sharing Center. Click and open to see your available network connections. If you want to see details for the network connection click on available connection and then go to details button.
I hope this will help you.
Hello Andrealaw_avis,
– On your Start Screen, right click in an empty area, click on All Apps and find Control Panel from the list.
– In Control Panel, click on Network and Internet, from there click on HomeGroup button.
– From there the procedure is just like it used to be Windows 7.
I hope this is what you were looking for. Thank You
Dear Andrea Law _ Avis,
Follow these main steps:
1-Â Â Â Â Â Â Â Summon the Charms bar and click the Settings icon.
2-Â Â Â Â Â Â Â Choose the Network icon near the bottom of the Settings pane.
3-Â Â Â Â Â Â Â Available network connections will be displayed.
4-Â Â Â Â Â Â Â For configuring settings of the connection, follow normal procedure.
5-Â Â Â Â Â Â Â Finally, connect to your desired network.
Hope that was helpful.
Best regards,
Don Muench
