amrinder64
20 points
Posted on - 10/19/2011
An administrator had six computers which were in his network. On analysis he found that two of the computer's can communicate with one another and 3 of the other computers could not have connectivity to the last PC not to the first two.
Propose Class B address for each of the computers.
Maryw102
Network communication problem one to another?
You have not mentioned which communication system you were using prior to this problem. Ensure that the communication Symantec systems' server is not older than the version you are using on your primary server. In real sense they should be the same versions. The Antivirus version installed on the Symantec's version should be the same as the one in the main otherwise called the parent server. Ensure that all of you practice safety in your working environment.
To get to secure your network, ensure that you are using programs that cannot be tampered with, ensure limiting of access to data and access to your services. Use encryption to secure all your data. Protecting your network using firewalls is also advised. This will help avoid intruders who cripple your network every now and then.
mc4321
To resolve network communication problems with PC clients or server, is to verify the basic network to the client and server by pinging on both vice versa tries this command # ping hostname. Check the computer name for verifying the client or server names and check the Netback up client if is running just use the service application to the Control Panel just verify if is running the Netback up Client Service and check the port number of the Netback up client .
You must verify or check the problem to enable to use the logs. You just restore interface or archive from the client through the File menu you just click the Netback up client Properties. Make sure you always verify the hosts name or Client-server connectivity.
