Network connection speed limiter, need help with this one
Hi guys, I have my brother with me sharing our internet connection. He often use the internet to watch video from YouTube.
I want him to limit watching from YouTube by slowing down net speed.
I need a network connection speed limiter. Where can I get this software?
or What do I do to limit connection?
Best Answer by Marshall Kwak
Answered By 0 points N/A #132946
Hello James Yorath,
Good day!
It's good that you have posted your concern on this site. Regarding limiting the connection speed you can try to follow these steps:
First go to Start and Run> then type "gpedit.msc"> press on "Enter."(Group Policy page will open).>Then go to Computer Configuration>Administrative Templates>Network>then>QOS Package Scheduler You can now limit outstanding packets or reservable bandwidth>just right click on the options to edit or make changes. If this won't work you can download a speed limiter software.
Good luck!
Rios Louise
Answered By 15 points N/A #132947
Hi James Yorath,
To limit the speed of a particular computer in your network, You can use a router that has QoS (Quality of Service) capabilities. Routers sold these days are usually capable of this.
To name one, the Linksys E4200 is capable of limiting internet speed to a specific device connected to it.
With this router, You can specify how much speed he will get or You can set his speed priority within the network.
Here is how the router's setting page looks like:
