Kim Wong
Posted on - 11/15/2011
Hi there!
Can you tell me where I can find Layer 1, Layer 2, and Layer 3 network diagrams?
It seems to me that companies project different ideas of what should be displayed in each diagram. Â I would also like to know if there is a manual or a book that provides clear uniform samples.
Thank you for any responses in advance.
Kim
Network diagrams for Layer1 and 2 and 3
Howdy Kim Wong,
Below are the links which I have searched which you can rely on to be able to solve your issue. Make sure that you read it very carefully to be able to understand that content of any of those sites.
It is really confusing but sometimes you need to be patient if you really want to solve your issue.
-Zorian
You need to search the OSI model over the network to find your specified data. You can find the relevant data in OSI model.
The OSI model consist of seven layers and each layer performs a specific task in a network. The model is used to connect tow computers over a network. You can find all the relevant knowledge on each layer in that OSI model.
Different companies can make their one layer structure but one of all that is most common is the same model i tell you.You can find your desired data on the following online.
