I am attempting to install Skype on my laptop. My system has the following specifications:
Windows 7 and 64 bit but installer always providing error message
"exe installer file is corrupt", and installer version 5.1
A network error occurred while attempting to read from the file: C:UsershouseAppDataLocalMicrosoftWindowsTemporary Internet FilesContent IE5FPA0QDGYSkype.msi
Hi James,
You can try the procedure outlined here to install a new version of Skype without using an installer program:
Community skype com t5 Windows desktop
Skype com en download
I would also advise you to make a copy of your currently installed Skype.exe file, just in case that you regret the update.
Pamela Conley
I have also faced this problem. Sometimes it can happen due to the antivirus program.
You need to disable your antivirus software first, then try to install Skype again,
Clearing all the browser cookies will also help. In Internet Explorer go to "tools" and then "internet options" and then click on "Settings". Here you will see the "view files" button. Click on it and delete all files.
Now try to install Skype again. Remember, after you have deleted cookies in Internet Explorer, don’t open any other browser.
This error can also occur due to your graphics driver. At one point, Skype did not support the new version NVIDIA graphics driver.
You need to install this driver and then try to install Skype again.
It should work now.
Good Luck !
Indeed your installed Skype program is corrupt or some files are corrupt.
I will therefore solve your problem by giving you a site where you can obtain a new Skype setup program.
The following is the link or alternative go to the this website
Regards.
josiel25
The version of your Skype is not compatible on your operating system which is windows 7.
Try to install another version of Skype.
Hello James,
Please make sure you login as an administrator before installing any software's as the system admin might have set constraints on installing and uninstalling software's.
It seems that the software package you are trying to install is corrupted or has some files missing from it.
Download fresh latest copy of the Skype software package from following website and it is for free,
And try installing it again.
Please follow all instructions properly.
Even if it doesn't work, restart your system and make sure your antivirus software is not blocking new softwares from installing on the system.
Hope it solves your problem and enjoy Skype.
Thanks,
Skype is a magnificent technology that allows people with a computer, internet connection and microphone to call others on their phone from their computer. Techyv has a post where you can see many Skype error as well solutions which will be helpful for you.
Guide to solving common errors/issues Skype users may face
