NETWORK IP ADDRESS Roland SC – 545EX
How to modify the IP number of Roland SC-545EX printer ?
I don't find network function on the menu. Do you know how I can ?
Whatsup,
That's a quite tricky question but it can be solved. What you need to do is to go to the bottom-right icon tray and right-click on the printer icon. It will show several options including properties.
Click on it and on the Properties window, click on the Ports tab, it will display the IP addresses of the printers and networks when you widen the first column.
You can also manually go to Start->Control Panel->Printers
You can now modify the settings as you want.
I hope this solves your issue
Thanks
