NETWORK MADE BETWEEN DSL AND WIRELESS
Hi Muhammad,
Having an internet connection in your iPhone is very easy. You should have an available internet connection and a router to share your connection, in your iPhone. Steps below will help you, enable your iPhone and access your connection.
Once connected, you will see a signal logo beside your network provider logo, on the upper left corner of your iPhone.
iPhone's Internet connection works only by using WiFi. You need to have a router at home to share your DSL Internet connection to your mobile smartphone. iPhone has built-in WiFi adapter installed that detects wireless signal available. You can configure to auto-detect wireless network name and connects automatically to the assigned network. Smartphone has this feature and it's so amazing to have this type of device.
Do this on your iPhone.
* Tab the Settings gear, this gives you list of options to click.
* Switch WiFi on and choose a network, Tap the Join Network.
* Set the Network Name/SSID, type the Security Key.
* Choose the corresponding settings, if it's a WEP, WPA.
* Tap on Join, this should let you share your Internet connection on your iPhone.
