Network Magic Setup For evaluation Purposes Only
While I was trying to configure Network Magic program this Error appeared. I made the right settings and I don’t know what missed. Any solution ? Can anyone help me please to make the right settings and please help me configure it.
Thank you !
Unexpected Error
An unexpected Error was encountered (0x643). Setup cannot continue.
Visit Network Magic Support for more information.
OK
Answered By 590495 points N/A #178934
Unfortunately, Network Magic is no longer available for sale starting August 31, 2012. It was replaced by the LinkSys SMART Wi-Fi. Though you can no longer purchase it, you can still download it from other websites. If you are using or want to install Network Magic on Windows XP, there should be no problem but you should be running Service Pack 1 and higher.
If you are not using Windows XP Service Pack 1 then this is probably the reason why it is unable to install on your computer. Download Windows XP Service Pack 1 then run the installer to update your operating system to Service Pack 1. If you still can’t install Network Magic, try updating your Windows Installer. Download and install Windows Installer 4.5 Redistributable and then see if it works.
Also, try installing the latest version, Cisco Network Magic Pro 5.5. It supports Windows XP Service Pack 1 and higher, Windows Vista, Windows 7, and Windows 8 both x86 and x64.
