Hello everybody,
I have Network monitor as one of desktop widget, and I am sure that it was working before, at least during, Live run before installation. But currently it gives me a White Square only, and no information within (just White Square).
When I try to configure it, I have found the drop-down list under network interface to be empty.
That is very strange, sine I am using WIFI network.
Please, I want your suggestions or ideas?
Regards.
Network monitor widget not working
Updating your D-Link router for monitoring, from your desktop is easy!
Download the latest firmware for your D-Link router here: DIR-625, DIR-628, DIR-655, DIR-825, DIR-855, DGL-4500.
Install the new firmware, by logging into the admin screen of your router. To log into your router, type 192.168.0.1 into your web browser, address bar and enter your password.
Download the D-Link Widget.
Install the D-Link Widget.
That's it! Your network settings are now displayed on your desktop!
I faced this problem before, and I believe the solution will be as follow:
1- Right click on desktop –> Gagdets
2- Right click on Network Monitor Gadget then Click ( Uninstall )
3- Go to the following web site http://download.cnet.com/Network-Monitor-Widget/3000-12565_4-10766706.html Then click on download
4- On the following screen click ( Install )
5- On the following screen click ( save as )
6- Select where to save your file (Network_Meter_V6.4)
7- Now, let’s install the Network_Meter_V6.4 on your computer
Then click Install
8- Now, you will find this Gadget on your desktop
9- Let’s configure the Gadget to your adapter
Click ( Options ) on the right hand side of the Gadget
