The network path was not found windows 7
I have issue from side to side state of affairs my home network; my laptop can’t access files on my HTPC. Both laptop and PC are running Windows 7 final. The PC is connected to LAN. Or router is a Net gear DG834 GV. Together PC need fix IP address. With network screen I am having an issue and I got error also. 0x80070035 network path equally could not establish.I have issue from side to side state of affairs my home network; my laptop can’t access files on my HTPC. Both laptop and PC are running Windows 7 final. The PC is connected to LAN. Or router is a Net gear DG834 GV. Together PC need fix IP address. With network screen I am having an issue and I got error also. 0x80070035 network path equally could not establish.
