I install Netbeans in my home it proper work but when I go to lab and try to use this program then I see error. Is this error due to network? Why NetBeans don’t work in lab.
I explain complete detail of Lab in our lab there is one server and 80 clients machines when I install it at client machine then this error occurred.
Complete Error Detail
Network Problem
Cannot read NBM E:Program FilesNetBeans
6.5javafx2updatedownloadorg-netbeans-modules-javafx-sdk-win.nbm
No all of the plugins have been successfully downloaded. The server may be unavailable at the moment. Try again later.
Network Problem Cannot read NBM E:Program FilesNetBeans
Hi Shaus,
Network Problem
This was your error message right? As you read the message, cannot read the NBM because of luck of file download. Meaning that before you can use that file you have to sure that you completed download all the files in that application. So for now recheck and also you can install the application then install it again but for now the complete one. Then recheck if the file was compatible n your system. it will help you. thanks
