anonymous
7060 points
Posted on - 03/05/2012
Hi. I need help on creating an essay that contains of not less than 500 words regarding Information Systems Security Policy. I need information on creating it to its usage and functions. Thanks.
Creating Essay Regarding Information Systems Security Policy
Things like that must be done by yourself or someone who you are going to pay for it. However I will specify key points here so that you can Google them later for your information.
There are a lot of information systems commonly known as IS that are designed for specific purposes like
Management IS
Decision IS
Maintenance IS
Scheduler IS
Support IS
Now all of these systems are allowed to work in a strict environment and as their name suggests the type of work they will be doing. The decision and management IS are commonly used by the company’s CEOs and chairmen and scheduler IS is used by the employees of the firm.
Remember that these can co-exist in the same machine until any of their modules don't collide with one another.
