fernerich
10 points
Posted on - 02/11/2012
For my Internet connection, I have decided to use NetZero as my ISP.
When I tried to install the starting software for NetZero, the error shown below keeps popping up.
I have tried to double-check whether NetZero is, indeed, already running, but the same error shows up even when I launch the installation for the first time.
How do I go about repairing this? Thanks, everyone!
Problem Starting NetZero
The NetZero software is already running.
You must close the software before starting it.
Error Code: 02
NetZero Software Does Not Install (Double Launch)
There are several troubleshooting steps you can do whenever you get this king of error:
First up, make sure your system meets the minimum requirements for NetZero:
– if you're using Win xp, here are the requirements:
– 800MHz or higher processor, 512 MB RAM,20 MB free disk space, 56k modem, Internet Explorer 7.0 or higher, SVGA monitor with 800×600 resolution
Check if NetZero automatically starts in start-up:
– look for the NetZero icon on your system tray
– right-click the icon, click on options, and uncheck Launch NetZero when I startup my computer
This will ensure NetZero doesn't run automatically when you boot-up.
Hope that helps!
