New arabic fonts 2011 for Autocad 2011
Dear Friends,
Dear Friends,
You can download new Arabic fonts which are supportive to AutoCAD 2011.
Download link: http://search.4shared.com/q/1/Arabic+Fonts+For+AutoCAD
AutoCAD supports two types of fonts they are:
1. SHX fonts.
2. Windows system TTF fonts.
SHX fonts can't be installed by coping the .SHX file into the AutoCAD fonts folder.
Eg.C:program filesautodeskautocad 2011fonts
TTF fonts should install in windows & through the windows control panel select font and select file menu in the AutoCAD & choose “install new fonts”.
Hope this tool will helpful to you.
Thanks & Regards.
Mckinney Ma
Hallo Dustin Albas,
I am giving all the exclusive references and guide regarding the topics.
You can find the Arabic fonts 2011 for AutoCAD
You can also get the tool "Arabic Tools for AutoCAD 2000 version 5.0 from http://www.freecadapps.com/swdetails.php?page=search&review=4320&
Arabic Tools for AutoCAD is a plug-in that allows users to add Arabic text to their drawings. It includes a number of utilities, such as text search and editing, text exploding, curve-fitting, and text export/import. It also features VisualSHX(TM), which is a visual SHX font editor.
This version is a full featured demo version which is restricted to 2 fonts. It includes an installation program and a manual. You can install the program by unzipping ARBTOOLS.ZIP to any directory, and then starting SETUP.EXE, which guides you through the installation process.
Best Wishes,
Shifflettt Laurel
