New Buffalo Portable hard disk drive
Buffalo has introduced new portable HDD.
Does the new buffalo Portable HDD supports USB 3.0?
And also What is the maximum data transfer rate?
Buffalo's DriveStation Axis™ is the new flagship of the Buffalo Technology which supports USB 3.0.
Hard Drive HD-LBU3 really supports USB 3.0 with a backward compatibility with the USB 2.0 technology. It is considered to be compatible with any Personal computer or Mac.
The maximum speed interface it provides runs up to 5 Gbps.
For Windows users, there are a lot of software included in the package and supports your Backing up and management requirements with the Buffalo HDD.
It serves optional software which can be installed on all your PC’s namely: Buffalo Backup Utility, ECO manager- an energy efficiency tool, RAMDISK-creates RAM Disk on your PC to work fast on files, SecureLock for data encryption.
MiniStation Thunderbolt/USB Portable Hard Drive is the new portable hard drive introduced by Buffalo this 2012. It is designed to support PC and Mac. It is easy to carry and can handle large files. It features USB 3.0 connectivity and backward compatibility with USB 2.0.
The USB 3.0 interface will supply a transfer speed up to 5 Gbps while the Intel’s Thunderbolt connection will deliver up to 10 Gbps transfer speeds. This is the first portable hard drive that combines the speed support of USB and Thunderbolt. It is housed in a sleek aluminum case with a transparent frosted top.
The base has an indirect access LED indicator that will illuminate a desktop or any other supporting surface.Through the convenience of this new external drive, consumers can now move large digital files faster and abridge connections between devices. MiniStation Thunderbolt/USB Portable Hard Drive would not need a separate power supply because it is bus-powered.
