New chrome update brought undersirable option
I really appreciate using chrome browser. I use it mostly for my work. The recent update has been causing me a few problem. The new feature of profiles have been the main source of predicaments. Is there a way to get rid of the profiles setting of chrome? I have to login to get access to all my pre-set features and this is time consuming
Answered By 590495 points N/A #189587
Just like what I always do, if I don’t like the improvements or the changes added to the latest version of a web browser, either I shift to an earlier version of the same web browser or use a different web browser. Most of the time if a new feature was added, it will stay there until they get tired of it and they will either replace it with a different feature or completely abandon and remove it.
For how long, no one knows because it always depends on the developer or if they received too many complaints about the feature. In your case, if you only want to get rid of the new Profile button in Google Chrome because it annoys you, there is a way to disable it but not to remove it.
If you want to disable the new Profile button in Google Chrome, here is how. Start Google Chrome then in the address bar, type without quotes “chrome://flags/#enable-new-profile-management” then hit Enter. It will supposedly lead you to the “Enable new profile management system” option of the Google Chrome web browser. Once it opens, disable the option then restart Google Chrome and the new Profile button will be gone.
