Fduchinar
10 points
Posted on - 07/28/2016
Hi, I was thinking of buying a new Dell XPS 15z but when I checked for the availability of its parts in the market, I got a little disappointed as I didn’t find any Dell XPS 15z replacement battery. Can anyone help me to decide whether it is still suitable to buy this laptop?
GuptaA
20 points
New Dell XPS 15z replacement battery availability
If you are satisfied with the services, applications and other functionalities of this laptop, and it suits the best with your needs, then I would suggest that you can buy this laptop.
First of all, upon a new purchase, it comes with a battery pre-installed along with a warranty period of 1 year in which you can get your battery replaced in case of any damage.
If you want to replace the battery after the warranty period, you can check for it on dell.to/kiJSP1
This website is regularly updated in case you might not find out any part at a particular time.
