New Dual Monitor Resolution Problem?
I have added two monitors to my new build but think it is causing resolution issues.  One monitor is 25" and the other is 28" both by Dell.  When trying to use them both they have the same resolution instead of one being better. Can the 25" limit the 28" from displaying as well?
Answered By 0 points N/A #191780
Yes, you are possible to set them as same resolution. If you are using duplicate screen, both monitors must display in same resolution. If you are using extended desktop, right click on your desktop, select screen resolution, then select your 28” monitor, and adjust the resolution same as your 25” monitor.
