New Flash-related technologies at Adobe Labs.
Hi everybody,
I’ve noticed that there are two more new Flash-related technologies at Adobe Labs.
If someone needs the tools of the CS3/4 from flex, he can find this from PatchPanel Library.
I also attended Dr. Woohoo’s session at FOTB, here I noticed the early preview of these powerful tools.
For AIR applicants, Durango is a rapid prototyping tool which has some rough edges.
I need to confirm, is it the wrong solution to the right problem?
What's your opinion about this?Â
Error:
Process terminated without establishing connection to debugger
Command:
*/Application/Adobe Flex Builder 3/sdks/3.1.0/bin/adl"-runtime*/Applications/Adobe Flex Builder 3/sdks/3.1.0/runtime/air/mac*"/users/jensa/Documents/Flex Builder 3/Application-0001/bin/Main-app.xml""/Users/jensa/Documents/Flex Builder 3/Application-0001/bin'' Output from commend:invocation forwarded to primary instance.
