I want to download a IDE software, I check lots of reviews. And I found Java SE 6.0 (JDK 6).
I want some ones advice over this software, I need someone who use this. Is this better than other software's ?
If not, can you suggest another software.
If it is good can you give its special functions ?
Thank you in advance.
New functions of Java SE 6.0 (JDK 6)
Java SE 6.0 (JDK 6) is not an IDE (Integrated Development Environment). Rather, its Java Development Kit for programming in Java Technologies.
NetBeans The Smarter and Faster Way to Code
Eclipse Announcements
Actually these are two free IDEs for Java. Both can be used for Desktop, Web and Mobile development using Java. Both IDEs come with Java Development Kit. No need to separately install Java Development Kit. Just install any one of these IDEs and start programming in Java.
There exist other IDEs for Java but these are best and most popular.
However, if you want to program in .NET then Visual Studio is best.
