New Generation iPad Battery life
hi avah
No, its wrong, the new iPad has improved battery life for the fact that new iPad has 42 watt-hours versus 25-watt-hours for iPad2. The increased battery capacity is used up to power enhanced components (Retina display and LTE networking technology), hence maintaining same battery life as 10 hours on Wi-Fi, 9 hours on cellular data of the previous iPad.
Though I have obsered it taking quite longer to charge new iPad.
Hope it works
Hi Ava. HAnnah,
I appreciate you for posting that question here. You said that there a rumor that the new ipad2 doesn't match its battery life. That is wrong the following are its specifications in terms of battery and power;
I hope the information above I have given will help you.
Mary
The Apple iPad Air (2019) is a 4G iPad operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public and released on March 2019 measuring 250.6 x 174.1 x 6.1 millimeters and weighing 456 grams. It is built with glass front, aluminum back, and aluminum frame.
It uses nano-SIM card and eSIM with stylus. It has IPS LCD capacitive touchscreen display with 16M colors at 1668 x 2224 pixels screen resolution. It is protected with scratch-resistant glass with oleophobic coating. It ships with iOS 12.1.3 upgradable to iPadOS 13.1.2 powered by 7 nm Apple A12 Bionic chipset, Hexa-Core processor (2 x 2.5 GHz Vortex + 4 x 1.6 GHz Tempest), and Apple GPU (4-core graphics).
It has no support for microSD. It runs on 3 GB RAM with internal storage available in 64 GB and 256 GB capacities. The primary camera supports 8 megapixels with f/2.4, 31mm (standard), 1.12µm, and AF featuring HDR. It supports 1080p video recording at 30 fps. The secondary camera supports 7 megapixels with f/2.2 and 31mm (standard) featuring HDR.
It supports 1080p video recording at 30 fps. It has 3.5-millimeter jack, Wi-Fi 802.11 a/b/g/n/ac with dual-band and hotspot support, Bluetooth 5.0 with A2DP and EDR support, GPS with A-GPS and GLONASS support (3G/LTE model only), and USB 2.0 with proprietary reversible connector support. It doesn’t have FM radio. It has built-in front-mounted fingerprint, accelerometer, gyro, compass, and barometer sensors with Siri natural language commands and dictation support.
It runs on 30.8 Wh non-removable Li-Po 8134 mAh battery with talk time up to 10 hours via multimedia. It is available in Space Gray, Silver, and Gold colors.
