New genuine window xp gets a problem.
How would you set the problem if your antivirus delete "rundll32.exe" file from your new genuine window-xp?
Shamoon,
It's very shocking to hear your query in saying that the file rundll32.exe has been deleted by the antivirus system present in your operating system. The file will not be deleted at all as you said that your operating system is genuine there may be no chance of deletion of the main system file you mentioned. The genuine operating system is the system that will not affect the any files regarding to the system until it is critical and even if it is critical warning will be issued to the user. The notification will automatically be displayed in the system tray even you set the options to off as it is very important notification and as it is regarding to your system.
Thank you.
Hi
Generally rundll32.exe is used to execute the files with .dll extension file type. It is necessary to run application software. However your antivirus have deleted the file you can take the following steps
Start your task manager by pressing ctrl+alt+del. When task manager window comes go to the “process” and check that rundll32.exe is displaying or not. If not displaying then use system restore to restore your windows to any previous time. It will also restore rundll32exe file also.
You can also use some registry fixing software to fix the file. One of the best registries repairing software is Registry Easy. With this software you can scan outdated or invalid entries and repair those errors.
Best of luck
