New Glary Utilities Portable 2.46.0
The effective pc maintaining software Glary Utilities Portable 2.46.0 is in market now. How much Ram do I need to run this software smoothly?
Glary Utilities is free software which contains set of utilities that enables you to increase the performance of your Windows PC improving their function. This software can clean your system and recompense the system. It cam optimize your ram memory and improve free memory space. Also you can use this to Scan and clean your registry entries and uninstall programs completely from your system to increase performance.
To know more about Glary Utilities: http://www.glarysoft.com/glary-utilities-pro/
The system requirements you need to install and run Glary Utilities without a problem are;
Windows 2000/Windows XP/Windows Vista/Windows 7 running system
Pentium III 700MHz or higher processor
128 MB of Ram
This is the portable version of Glary Utilities and this portable version doesn’t include an installer. It is an intelligent and dependable program that provides various powerful tools and utilities to repair, maintain, accelerate, and guard your computer. It lets you clean usual system scrap files and also internet traces and invalid registry entries.
With this utility, you are also capable of removing and managing the add-ons on your web browser, scan for duplicate files, and disk space usage. It also allows you to manage and view installed shell extensions, encrypt your files so no unauthorized users can access it, and split and join large files.
In addition to that, it also contains options where you can optimize your memory, manage startup programs, and find, fix, and or delete broken shortcuts in Microsoft Windows. Download and install Glary Utilities Portable 2.56.1822 instead of the one you have which is already an old version. This one works with Windows XP, Windows Vista, Windows 7, and Windows 8.
