I recently bought a western digital 320 GB ultra portable hard drive while I was on a travel trip. The problem is that when I reached home and opened it from its packing, upon connecting it asked for a password.
I checked the manual but there seems to be no reset password or in fact any kind of password.
I can’t return it because I bought it from another town and lost the receipt while on the trip but its brand new and in packing so I guess there must be some, factory reset password.
Please if anyone knows about how to reset the password do reply?
jenny.k
New hard disk with a password
Hello Scot Stunner, You can follow some steps. There are many software over the internet which provides the password recovery. You can try them all. Secondly, set the hard disk in your motherboard as the primary device. then boot your windows from the CD ROM.
While you see the hard disk in a raw format delete the whole thing and then you will be able to format it. This is how you will be able to remove the password.
dean01
So its an external hard drive, No need to worry just follow this easy steps in order to wipe out clean that HDD and remove the password:
Plug in your hard drive.
Open m computer.
Right click your external Harddrive.
Select format.
Now ensure that the file system is in NTFS.
Under format options check quick format.
Now hit start.
Wait for a few minutes.
After it successfully formatted the drive try Opening it and see if the password is still there.
If not congratulations! You can now access your driver.I hope this is helpful. Thanks.
