The New IOS 6 will it automatically use wifi plus cellular connection
Will the new IOS for IPhone 5 finally be able to switch over from WiFi to Cellular connection when The WiFi is really slow.
Dear User,
The answer in short is Yes! It is said that the new iOS 6 will have a selection in the settings area of your phone that will set your phone up to switch to the fastest network, be it WiFi or cellular. So whatever the best connection that exists, iOS 6 will find it for you.
Also in the settings area, you will be able to specify whether you wish to use iCloud, Face Time, or iTunes when connected to your cellular network. Thus aiding in the data usage management.
Thank You!
Dear User,
Yes it is. Many times we wonder when trying to load webpage using a very poor WiFi connection. Can’t it be automatically use 3G.
With this new iOS6 it can happen. You will be able to use WiFi plus cellular internet connection without having no further troubles regarding this matter
You can easily select this from you setting, by simply selecting “apps having trouble with WiFi to use cellular data”
Believe it, that the new iOS 6 comes with many gifts and services. That can amaze the apple users.
Thank you.
