Is the new iPhone 4 Accessory Audio Boosting V-Moda Vamp durable?
It looks hefty, what are the unique features that makes it different from other audio boosting accessories?
V-moda is a protective case made of  aircraft-grade brushed metal and shock absorbing silicone that can keep your iPhone from scratches, dents or breaks with a 2200mAh lithium-ion battery provides up to 8 hours of playback, it can serve as a backup power source and double the iPhone's battery life. It also boosts the iPhone’s audio output quality.
The V-moda also contains its own Digital to Analog converter that extracts the iPhone's digital output and converts it into its analog form or signals for audio listening. It also has its own powerful amplifier, a 150mW x 2 amplifier bypasses the iPhone's internal amp intended for smaller ear buds and provides optimal power to drive even the most demanding headphones. Its VAMP's rotary volume knob allows you to finely adjust the volume and the output level.
