New laptops from fujitsu ?
Recently fujitsu has launched two laptops which especially support for windows 8? Can anyone list the features and specifications of those two laptops.
Dear Bridgette M Roth, I have read your query.
Yes, you are right. Fujitsu have launched 2 Lifebook Tablet PCs recently with windows 8 support. These 2 are Lifebook T731 Tablet PC and Lifebook T901 Tablet PC. Actually these 2 are part of a offer, which is that you will have to buy a Windows 7 PC Tablet and will get Windows 8 Professional for 14.99 Us Dollars. This offer will be available on June the 2nd 2012 and will be valid till January the 2013.
As for Lifebook T731 Tablet PC, these are some of specifications:
It is equipped with 2nd generation i5/i7 processor, with memory up to 8GB and Mobile Intel QM67 Express chipset support. Display is 12.1 inch WXGA LED with Intel HD 3000 Integrated Graphics. It is equipped with active/dual digitize. Hard drive capacity is up to 500 GB. Don’t have webcam, but can be upgraded. It comes with biometric fingerprint sensor.
As for Lifebook T901 Tablet PC, these are some of specifications:
It is equipped with 3rd generation i5 processor, with memory up to 8 GB and have hard drive capacity of 320GB. It comes with 13.3 inch widescreen display and have intel HD 3000 graphics. It has 2 mega pixels web cam.
Hope it helped.
