New mobiles from Motorola India
Motorola has launched motorola defy XT and defy mini which is dual sim mobile ? Can anyone list the features of these mobiles ? And how is this different from defy plus ?
Motorola DEFY XT has a 3.7-inch screen, 5 MP camera and a VGA front camera and it runs on 1GHz processor and 512 RAM. The handset runs on Android 2.3 and has a 1650 mAH battery, which is expected to give 9.5 hours of talk time. Motorola DEFY XT has MicroSD card support with 2GB MicroSD card included and it is also water resistance and repellent and dust resistant. It has WiFi, GPS and Bluetooth support.
Motorola DEFY MINI on the other hand, has a 3.2-inch screen and 600 MHz processor. It sports a 3 MP back camera and a VGA rear camera. Motorola DEFY MINI runs on Android 2.3 and has a 1650 mAh battery. Priced at Rs. 11,490, this handset also has MicroSD card support with 2GB MicroSD card included. It is unlike Motorola DEFY XT also has water resistance and repellent and dust resistant body and for connectivity also has WiFi, GPS and Bluetooth support.
Motorola DEFY XT is same as Motorola DEFY+ but Motorola DEFY MINI is low configured then Motorola DEFY+.
There are different models of the Motorola Defy XT phone and one is the Motorola DEFY XT XT556. The Motorola DEFY XT XT556 is a 3G Smartphone operating on 2G and 3G network bands using CDMA and EVDO technologies. It was unveiled to the public and released on July 2012. It measures 115 x 58.5 x 12 millimeters and weighs 130 grams.
It uses mini-SIM card with IP67 certification: dust tight and water proof for up to 1 meter for 30 minutes. It has TFT capacitive touchscreen display with 16M colors at 480 x 854 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass with touch sensitive controls. It runs on Android 2.3 Gingerbread powered by 1 GHz processor. It supports microSD expandable up to 32 GB.
It runs on 512 MB RAM with 1 GB internal storage. The primary camera supports 5 megapixels with LED flash and autofocus. The primary camera features geo-tagging and can record video in 480p at 30 fps. The secondary camera supports VGA.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic support; Wi-Fi 802.11 b/g/n with Wi-Fi Direct, DLNA, and hotspot support; Bluetooth; GPS with A-GPS support; FM radio; and microUSB 2.0. It has built-in accelerometer, compass, and proximity sensors. The pre-installed web browser supports HTML. Java is supported via Java MIDP emulator.
It runs on removable Li-Ion 1650 mAh battery with standby time up to 300 hours and talk time up to 5 hours 30 minutes. It is available in brown color.
