New PDF Converter Pro 3.2.0 Plugin for Ms-Word
Hi there experts!
The latest release of the New PDF Converter Pro 3.2.0 by Wondershare has proved to be really useful in my daily works.
But I accidentally removed the plugin of this software from my word file and now I can not find it,
I thought it would be there somewhere in the Add or Remove Buttons category, but it is nowhere to be seen.
Can anyone please help me out?
Waiting for a helpful reply.
Best Answer by Franks good
Answered By 0 points N/A #154111
Hi.
I am there to help you. you said that you used New PDF Converter Pro 3.2.0 earlier,from where did you get that?.
I think you have used the free trial version of it so check that carefully.
Thank you.
Answered By 15 points N/A #154112
The Pdf converter 3.2.0 you had was a beta version.
Any way you only have to install this plugin again and they will automatically get attached to your word.
You can find pdf plug-in free from different links. One link I will add here.
https://labnol.blogspot.in/2006/09/office-2007-save-as-pdf-download.html
Download it and install it and you will get your plugin back.
