Scott Broek
20 points
Posted on - 04/18/2012
Epsons unveils its new projector called the 710 HD for home theater.
This projector supports 720P resolution.
Can I use this projector with my Personal Computer with the same resolution?
dioal
New Powerlite Home Cinema 710 HD Projector from Epsons Unveils
Epsons unveils its new projector called the 710 HD for home theatre. This projector supports 720P resolution. Can I use this projector with my Personal Computer with the same resolution?
Hi there, Yes you can use your Personal Computer (PC) because the Epson PowerLite Home Cinema 710HD has Native Resolution: 720p (1280 x 800) WXGA .
And Epson 710 HD also supports this resolution to 640 x 480 (VGA), 1024 x 768 (XGA), 1152 x 864 (SXGA), 1400 x 900 (WXGA+), 1440 x 900 (WSXGA), 1680 x 1050 (WSXGA+), 1400 x 1050 (SXGA+), 1600 x 1200 (UXGA), 480i, 480p, 720p, 1080i, 1080p.
In that case, you can have a lot of options so there's nothing to worry about so your problem is solve.
Good Luck
As per the product specification it is capable of rendering of small or large displays, but besides the resolution, other technical variables need to be considered as distance, environment of room.
