The new trial version of Kaspersky Home antivirus
Since I was no longer using an antivirus, I thought it might be time to protect my computer a bit, now that I have a lot of important files and I can not afford to lose them or get them infected/damaged. And I wanted to know a little more about the new trial version of Kaspersky Home antivirus. Is it such a good antivirus, because some people were very happy with it, while others recommended other antivirus software. What do you guys think? Should I give it a try?
Best Answer by Boyer Britten
Answered By 0 points N/A #174593
Dear John
Kaspersky Antivirus is a popular antivirus but in terms of performance, I would recommend the Bitdefender antivirus to you. The Bitdefender antivirus is available at half the price of that of Kaspersky if at all you don’t get an illegal version or trial. The Bitdefender antivirus comes with loads of features and also boasts of the auto-pilot mode. I would say that Bitdefender is a digital dragon that protects our system from internet evil. The Bitdefender offers effective security, simple usability, effective resource usage and an enticing price point, Bitdefender Antivirus Plus is the best antivirus software. This antivirus doesn’t sacrifice with speed, what most other antivirus does!
So I suggest you to give Bitdefender a try.
Answered By 0 points N/A #174594
Hi John
For me no. Because Kaspersky home antivirus has many issues. I would recommend Avast 2014 for you I have  been using it to protect my files and it really work well. If you're having doubts you could try its Trial Version.
