New Ultra Mini Wireless USB 2.0 Nano Network Adapter Dongle by SANOXY
Is there any LED indicator if the signal is poor or good? Is there any added features like WiFi Protected Setup (WPS)?
You can use Amped wireless for a better solution. It enabled with WPS, that means It has a WiFi protection capability. It serves you LED indication and also WiFi activities. It has a wired connection capacity and also wireless activity with a huge perfection. Learn more about to having it and be getting solved from your problem, visit here- https://www.ampedwireless.com/
Actually when you want to an LED indicator it’s also wants from you to have a wireless protection so as WIFI that keeps your monitoring more efficiently.
Here is a another suggestion for you. Visit this site and make a decision. Though I appreciate more about the first way I suggest you.
Hope you can get relief.
