New video editor for Linux
Does any one know how to use flowblade video editor?
How can we install it in fedora 17?
What all videos can we edit using this editor?
Flowblade Movie Editor is a multitrack non-linear video editor for Linux released under GPL 3 license
Flowblade is designed to provide a fast, precise and as-simple-as-possible editing experience. Flowblade employs film style editing paradigm in which clips are usually automatically placed tightly after the previous clip – or between two existing clips – when they are inserted on the timeline.
Edits are fine-tuned by trimming in and out points of clips, or by cutting and deleting parts of clips. Film style editing is faster for creating programs with mostly straight cuts and audio splits, but may be slower when programs contain complex composites unless correct work flow is followed. Flowblade provides powerful tools to mix and filter video and audio.
Open Downloads -tab and download file flowblade_0.6.0-1_all.deb. This has been tested on Ubuntu 12.04 and Linux Mint 12, it should also work on Ubuntu 11.10 and quite possibly on other recent Ubuntu based distributions. Double click to install.
Installing From Source Archive
Open Downloads -tab and download file flowblade_0.6.0.tar.gz  Extract archive into a folder of your choosing Install dependencies. Launch by running script …/flowblade-0.6.0/flowblade that was created in the folder where archive was unpacked Flowblade is currently a 100% script application, and all the dependencies should be available in popular distributions, so in most cases it should be possible to install Flowblade without compiling anything.
You can find reference guide here.Â
